ERROR-Importing .dwg file from Inventor 2018 to sketchupPRO 2017
Hello guys, I have a problem with importing .dwg file from inventor 2018 it shows me this error but if i export them from inventor 2017 it works well. Thanks.Error sketchup
I am fairly certain that the 2018 version of DWG was release AFTER SketchUp 2017, thus we don’t support it… Yet…
Simple. SketchUp 2017 was released in the fall of 2016. Autodesk’s version 2018 packages were released in March 2017, and introduced a new DWG file format that no other software supports yet.
Thank you guys my bad i used .stl
Autodesk applications also support saving to older versions of the DWG format. Version 2010 or 2013 should work. Version 2018 is the first new file format since the 2013 one.
open with free ‘Teigha Viewer’ f. WIndows & Mac OS and save down to the DXF/DWG version desired, nothing after DXF/DWG r2000 does add substantial information.
