Hi, I need help understanding why my profiles are intertwining after using the follow me tool along a curved line. A picture is attached. Thank you.
The profile is always kept perpendicular to the path segments. That is why a clean radius of 0 does not work. You get better results if you follow round a full circle and remove the excess.
I tried again with a vertical profile and a path segment. It did not work. My path segment was created using the spline bezier curve tool, then I added a straight line to be perpendicular.
The radius of the path must be bigger than the width of the profile.
The profile arcs are causing an overlap, adjust the arcs so they connect.
Attach your model for a better answer.
Thanks, it worked using simple straight and curved lines instead of splines. Even if I wanted a different shape.
