Hello, I have a false face with several cut faces inside a simple rectangle face. I cannot select the whole rectangle surface, only several parts. It seems like something invisible is cutting the surface.
View hidden geometry and you will see the additional lines.
The surface is folded, not flat, distorted or not modeled correctly.
Could also be flat but divided by edges that have been hidden
Thank you! I have removed hidden geometry
