EPS export function no longer matches scene render
Hello All.
I regularly combine exported eps files with my matched rendered views using Illustrator. I have recently found that I am unable to export eps files that match my renders i.e. they appear to be exports of very zoomed in areas. This is a problem as it’s the primary reason I use SketchUp Pro. Any help would be greatly appreciated.
Thanks.
Maybe there will be more answers if you share some screenshots to illustrate the problem…
