only supported by 64 bit Windows is circled two post above yours…
your profile says your on a mac…
are you trying from bootcamp?
john
john
That was my fault, I suggested it, not even thinking that it was Windows only. It installs on Mac perfectly well, and then for me calls a shell script under Parallels. It was only Catalina file permissions that stopped it working for me.
But, not everyone on Mac has Windows 10 running at the same time on the same machine as Mac SketchUp running.
Franco did go on to start his own post about his case, which hopefully will have a happy ending, if it is the sample files I think he is using, because they come with 2016 versions.
Just a guess, but your User-name in Windows does not follow the recommended format [ASCII character letters and numbers only] - seems to be in Cyrillic ?
Windows / Ruby / VBS can trip up on this kind of thing…
Why o why did i not find this years ago
This is a blessing thanx a bundle @eneroth3!
Likewise, @ work SUP2021 and @ home SU2017.
Hello, thank you for this very usefull extension !
I there any planned update to support 2022 sketchup files ?
Bests,
Do you have v1.0.7 ?
It was updated to support 2021, and that should make it work with 2022 as well.
FYI: With the 2021 release the SKP file format was overhauled to make it versionless.
So if the user has SketchUp 2021 (or higher) they no longer need such an extension as SketchUp can now natively open model files created with any older or newer SketchUp version.
When the user saves a model that was originally saved with a newer version (than they have,) SketchUp will warn them that they might lose newer features.
I’m running Sktechup Make 2017 on Windows 11 64bits.
There does seem to be a difference between what versions are said to be supported, and what happens when you point to a 2022 file.
@eneroth3 may have suggestions.
As said above …
There is no way that SketchUp 2017 could have foretold the later change in SKP file format.
So the version of the API which is embedded within SU2017 would likely not know how to open the newer (post 2020) SKP file format.
It might be possible for this extension (or a standalone command line utility) to create a converted copy of post 2020 SKP files and backsave to 2017 format using a recent version of the SketchUp C API.
Manually, you may be able to open the newer file in the web edition and download it to your computer in 2017 format.
The file open_newer.rb hasn’t been updated since August 2021 and still contains the line:
HIGHEST_SUPPORTED_SU_VERSION = 21
Change that to 22 and you’ll be good to go. Look for the file in the plugs\ene_open_newer folder.
Strange that the Extension Warehouse lists this as compatible with 2022. A small oversight I’d guess
Perhaps change it to 30, to keep you going for many more years!
I’ve finally had the time to update the extension! Now 2022 and (hopefully) all other versions released in a near future should be supported.
Sorry for the delay.
Mine has the same issue when using the “Open Newer Version” plugin. The file doesn’t open and prompts this error message and then the whole SketchUp will crash. My OS is already 64-bit. I’m using License Sketchup Pro 2018. Is there anyone from this thread who encountered the same issue and solved this problem? I would gladly accept any help from you guys. Thanks.
Go into the Windows Apps & Features, and search for C++
There may be more than one entry. Click on one of them and choose Modify, then Repair. After the repair, reopen SketchUp and see if you still get the error.
Perhaps Julia used a newer version of the VC Runtime which was released after SketchUp 2018. So then @karloleobrera18 would not have it.
They may need to go to the Microsoft download center and download and install a later version of the 2019 Runtime libraries.
Thank you so much, worked perfectly!
Thank you a thousand times !!!
