Dynamic component with a cutout
Hi, I’m looking to create a component that can change the dimensions of a cabinet unit, but there’s a problem: the cutout in the body changes its dimensions, scales, and collapses. On the other hand, I can’t define separate pieces because I’m having trouble getting the cutlist in the open cutlist plugin, and it considers the pieces as separate.
Is there any way to create cuts in the body that keep their dimensions and positions constant?
if you make the pieces Dynamic groups, then OCL will not read them
alternative, can use DC holes and edge bands, OCL does not read 2D or cuts
hole in sheet.skp (35.0 KB)
you can later add the cutout detail to the reports using a DC attribute
I have still much to learn, thanks.
