Hello, I have a piece of kitchen furniture in sketchup. I want to convert it into a dynamic component so that it is easier for me to apply it to different spaces.
I was doing some tutorials, and I learned how to scale it, keeping the thickness of the components, and it works perfectly.
If you look at the images that are attached, you will see that the sides of the kitchen cabinet have a cut out where the furniture handle rests. The problem is when I scale the furniture in height or depth. Because that cut is disproportionate, with its real dimension.
How can I make sure that when I scale the component, that cut keeps its proportion?
In order to keep the thickness off the panels you needed to divide the cabinet into different parts, in order to keep the ‘gap’ the same size, you need to divide the panel itself in (2 or 3) parts:
divide the end panel into two, hide the co-joined surface and lines, and treat the individual components with their own set of position and size attributes
You could probably get away with just 2 pieces. If you want the toe kick part to “Always” be 3”x3” or whatever; You make a piece the height of the desired toekick, and use a variable to control the length to always be 3” shorted than the cabinet sides.
side_depth = x,
toeKickpart_depth = x-3.
And the side part could be the full length desired and the height can be an input value less 3: (side.height = input_Height - 3).
If desired as an option you could add inputs for toe kick height and depth and incorporate those to size of the toe kick part and incorporate that with the variable from the side dimensions;
tk_height = 2, tk_depth = 2, height_input = y
side_depth = x,
side_height = y - tk_height,
toeKickPart_length = x- tk_depth
