I am currently running a trial of Pro so as to get myself used to Dynamic Components to discover if it is a viable purchase.
However, I just started by running through some basic skill-builder videos on Youtube and have discovered that there appears to be a bug and when trying to create a dynamic cube as per the video, when setting a custom attribute ( size ) to basically adjust all Len dimensions equally and therefore keep a cube by just entering one attribute cm/inches give out opposing results.
Example…All my dimensions in ketchup or metric and I work in MM, so I, therefore, use CM in the creation of DC’s but when I have the custom attribute ( size) set to cm or mm the output in the sketch up component and the relevant SketchUp options box for an end-user to edit becomes inches and when I change it to inches it then becomes mm.
Any advice on me potentially missing something or is this a bug that needs fixing.
Eager for a rapid response, especially getting to the bottom of this before my trial ends and still get some proper functionality out of the trial.
Paul.
