I’ve drawn up a plate section in Autocad 2022 but when I import it to SU 2021 it is not even slightly accurate - holes that should be round are random shaped, there is no detail etc.
The only way I can get it to look anything like it should is to explode the DWG, however this makes it so surfaces are not recognised and SU just sees it as a collection of lines.
Really struggling with this and I need the SU model to show the concept to people without AC…
Importing the file as meters and exploding looks OK to me. I would guess that the AutoCad blocks had their origin points somewhere on the other side of the Moon. I don’t have AutoCad, only a viewer so I couldn’t check.
I see. You can do a lot of things with the SketchUp model. You could add a texture or show the thing in use . Maybe make an exploded view. Use LayOut to create a document showing the objects with dimensions and other information…
