I have imported a DWG into LO. Both drawings are attached.
The original is all in metric but the dimensions showing in LO are in imperial. The LO template setting is metric.
I don’t want this to happen so is there a way to make sure that a metric dimensioned DWG imported into a metric LO template ends up with metric dimensions and does not get “Americanised” in the process?
Also… LayOut groups entities based on the ACAD layers so you can adjust stroke by double clicking to enter the Scaled Drawing and set the Stroke to the group level.
