DWG Import from Revit causes display error on geometry
Hey
I’ve imported a 75mb DWG from Revit into SketchUp Pro 2024.
The problem I am facing is that all geometry is warped and not straight - until I enter each individual group/component.
How can I fix this? I have tried to explode the building into seperate groups without luck.
As you can see in the image below, the section plane shows the correct geometry.
Unfortunalty I will not be able to share the file.
Best
Theodor
Probably the model is too far from the origin (0,0,0).
Untick
wrt-02
Is the model exported from Revit with shared (map) coordinates instead of project coordinates?
Hi, just doubled checked and it was imported without preserved drawing origin
But have you checked how far from the origin it is?
Yes, the origin is currently in the middle of the imported model
Thanks! This fixed it :slight_smile:
This topic was automatically closed after 186 days. New replies are no longer allowed.
