Hello. When I import a dwg-file i recieve the right scale. However some text are marked as red arrows instead - how can I see the text?
Also, is it possible to do a bouning box so the lines of the imported DWG-file only are inside the page?
The red arrows indicate the text is too large for the text boxes. You can either edit the text to make it smaller or enlarge the text boxes.
Evidently you have the scale set larger thn the paper will hold. You can change the scale or you can edit the geometry within the group and cut it where you want it to end using the Split tool.
Since this is regarding LayOut, not SketchUp, I’ll move it to the LayOut category for you.
Thanks!
