DWG/DXF export selection only
Hi,
I often need to export parts of the model to DWG or DXF.
At the moment I have to delete everything but what I need to export, export, undo the deleting.
I already do this with a script but for larger models it takes quite a bit to undo the deleting.
Is there any other way to do this?
It is a bit strange, IMHO, that other exporters (collada, etc.) have the option to only export the selection while the DWG/DXF one doesn’t. Is there any plan to add this functionality?
I am open to better way to do it by scripting if there is any.
Thank you in advance for your time, best regards
Select the objects/parts > Make Component.
Select the component > right click on it > Save as.
Open the new model (component) > Export as DWG.
In the original model undo/explode the component to return to the original structure.
I do this several times per week for shop drawings to IFC, but should work just as well to DWG.
Select the components / groups you wish to export (I use tags to isolate the different parts of the model):
Edit>Copy…
File>New from Template (choose ‘plan view’ or any of the basic templates without the person in it).
Edit>Paste in Place…
File>Export 3d Model
Close the new drawing without saving, go back to working in your existing model.
Thanks for highlighting this, that is something to improve for the future.
