When I import a DS file of a furniture to my SU drawing it looks like this
Where can I remove the lines and add texture instead? Thanks
Where can I remove the lines and add texture instead? ThanksWithout the edges, it won’t have faces.
You want to smooth the edges.
Thanks - I´ll have to work on that. I got the cleanup plugin, but has to figure out how it works. But thx for now
Hi Lone,
There’s a user interface panel in CleanUp3 that lets you set the things you want it to do. For your chair model, you’ll want it to merge coplanar faces which will erase edges that aren’t needed. Then down at the bottom you can set it to smooth edges so you don’t have that as and extra step. Note this can be set to run on the selected geometry or on the entire model.
