Draping not working - Please HELP!
Hello,
The draping function is not working properly and I’m not sure what the problem is. I have attached my file. Please help if you can!
Jina
Not sure how to load my work…
Presumably it’s larger than 16 Mb. If so, upload it to DropBox or WE Transfer and share the link.
Great idea! Thank you.
What do you want to drape onto what? Are you trying to drape the edges on the large surface onto the contours?
If that’s the case you need to have a surface onto which the draped edges can fall. First create a surface from the topo geometry (or use the imported terrain.
You’ve got things messed up pretty good with lots of tagged geometry and most of it is loose.
I fixed the incorrect tag usage.
Screenshot - 6_12_2023 , 12_34_11 PM
I made a component of the terrain surface and softened those edges. Then I ran drape selecting the trail group and then the terrain group. It takes a few moments because there’s a lot of geometry to work through but it does work.
WOW. I don’t know how to thank you enough!!! Really appreciate the help!
Have the BEST day!
