Drape Command not working properly
I’m having an issue with the drape command not splitting the projected surface. Prior to the drape command, the line work produces surfaces as intended, but when it is projected onto the surface, the edge line isn’t recognized. I have tried using edge tools to identify any gaps, which says there are none. I have looked for unconnected edges manually, which there are none. I am stumped, if anyone has a solution, I am all ears!
I have worked with this topography before, and have been able to get the split to work, for whatever reason, it won’t anymore. Thanks in advance!
Look for ‘soft and smooth’ edges
I was able to get it to work, kind of, I ended up trimming the edges where it was flush with the topography.
