I have recently had the following start to occur when I try to drag to select in SketchUp Pro 2016.
This hasn’t happened in all the years I’ve been using SketchUp, but I’ve already found a few forum posts about this issue and have worked through the suggestions I found.
I have already downloaded and installed the latest graphics cards drivers, but this didn’t make any difference.
Disabling hardware acceleration in OpenGL does stop this from happening, but it makes SketchUp run poorly (seems to have a very low FPS) are there any other solutions to this problem?
Didn’t it happen before with the same install of SU Pro 2016 and on the same machine?
The latest driver isn’t always better in regards to OpenGL and SketchUp.
You may need to roll back one or two steps to a previously used driver. Windows 10 may have messed up your graphics card performance while updating.
I tried changing the capabilities from [93 64 bit] to [52 True Color] and that has fixed the issue.
I’m certain I’ve never changed that setting so don’t know what caused it, but it’s working now.
Thanks for the help
