My first CAD degree was acquired back in May of 1986. Trained on a lot of different systems. Can’t figure out the appropriate search terms, but trying to determine if SketchUp (Pro) has a feature that allows you to define wall types, e.g. 2x4 studs 16" o.c., 1/2" gyp board interior, exterior 7/16" OSB, housewrap, lap board siding.
Home Designer Pro has such a feature, but is also tedious to use in regards to other drawing options.
I really want something that has the wall definitions capability, but more of the ease and intuiviteness (good word, huh?) of SketchUp.
SketchUp has the ability to add third party features by adding plugins, these allow you to customize SketchUp to suit your needs. PlusSpec is one such plugin that can added to SketchUp and will provide the features you are looking for.
In SketchUp go to the Window menu and select Extension Warehouse, This is the easiest way to browse and add plugins to SketchUp. once there a simple search for Plus Spec will lead you to the information page about the plugin and allow you to install a trial version.
I just discovered that doing a search in the warehouse gives me a TON of options, none of which are named Plus Spec. So, I clicked on your link and will try downloading that way. Bit of a pricey tool, but also appears to be what I’m looking for.
Really hate that the annual lease is more expensive than the other software package I’ve been using. Are there any other similar, but free or more cost-effective options that you’re aware of?
