Do I need sketchup pro to use Polycam app for floorplans?
I haven’t used Sketchup in about 4 years. I learned the basics for a personal interior design project and have forgotten most of what I learned. I saw that you can now make floorplans with Polycam and am planning to try that out for a current personal project. Do I need to upgrade to pro in order to add the Polycam extension? I haven’t been able to find an answer to that by googling. Thanks in advance!
Extensions are only able to be used in SketchUp for Desktop, so you would need Pro.
Thank you so much! I’m not great with technology, so I appreciate you answering kindly.
I thought polycam was a stand alone phone app that scanned and then downloaded as an .obj which could be imported to SketchUp. It’s a separate app from a separate company with no affiliation to SketchUp. That’s what I remember when I used to use it, unless they have developed an extension which I have never heard of. (EDIT: as @KyleB points out below, there is now a direct import extension available, but you still need the app to scan from your phone) Get Polycam on your phone, can’t remember if they still have a free version, scan and email the scan to yourself within Polycam then import to SKUP
If you have an iPad Pro the iPad version of SketchUp includes a room scanner direct to SketchUp that uses the iPad lidar to scan
Polycam is a 3D scanner app, you can download and export the 3D scanned geometry and import from sketchup, I don’t think sketchup has a native obj importer, and the free version is quite limited on that aspect, you’ll probably need a desktop version, install TTlib and quadface tools to have an obj importer or any other importer plugin like universal importer.
There is a Polycam Extension in the warehouse - this is what I was referring to…
PolyCam Extension is really great. You can import your scan directly into SketchUp. You receive a textured mesh similar to usdz models.
