SITUATION:
drawing with 4+ section planes. section planes are active depending on the scene.
PROBLEM:
using the section tool bar and clicking the button Display Section Planes - toggle section planes on and off will do exactly what is says, but it will no longer saves my selection between scene navigation. When I click on a new scene my section planes are visible again even though I toggled them off. I have had this in the reverse as well. I can’t have section planes stay visible when I switch between scenes. This is causing a nightmare for me when I print drawings and all the section planes visible.
Take a look at the Scenes window. Active section planes is one of the checkboxes for what will be remembered by a Scene. Make sure this is checked, set the section planes as you want for that scene, and then update the scene. You will probably have to repeat this for each additional scene.
Thanks for the reply slbaumgartner. To futher clarify, the section planes activate and cut the drawings properly they are not hiding and unhiding the framework and arrows of the section planes properly.
Yes I believe so. This video shows what happens as I update each scene after toggling off the section planes. (screen capture does not show right click menu. but I am updating scene, and it is saving)
