Dimensions tool/tape measure unit display default
So, this is the best response to a question about an application I’ve seen. It took forever to get here, but I’m including this in the tests sets I use in my communities. Such good work. Keep it up!
My preferred access would be:
  • Tools/[mouse-R-click] Dimensions, pop-up window → select Units
Rock on,
Simon
I realize this is an older thread, but I got here googling for a similar issue.
In SketchUp Free (web), I found that switching to Tape[t] when I had re-opened a model defaulted to x’ y" display, which is not what I want to see. I always work in fractional inches only (woodworking stuff). There is a not a discrete setting for this that I have found in Free.
However, if you select Model Info > Length Units > Choose Decimal Inches, click away from the open sidebar in the model, and then switch back to Model Info > Length Units > Fractional Inches your readings from Tape are now in just fractional inches - no feet!
This seems like it may be a bug, but I was happy to find a way to turn off the x’ y" display. I’m not sure how to deal with the UI and large number of combinations adding in “inches only” display would create. I am sure that a very clever UX person could make it work.
I am looking for this answer in sketchup for schools. I am familar with the software versions to go to window>model info> units.
However in the web version, there is only feet inches or decimal inches. It is much easier for students since tape measures read inches predominantly.
thanks
You can set the units in Model Info. Use Decimal inches to get inches only
