Hello! When using the rectangle tool, i first clic on a point then move the mouse in the direction I want, then type the first measure, a come, then the second mesure. Only, the program will only use the first one I entered and use the cursor position to set the second measure.
First, drag out a rectangle and look closely at the dimensions displayed in the Measurements window. Are they separated by a comma or a semicolon? Use the same separator.
Make sure you are not adding a space after the separator and that you are not clicking in the Measurements window.
You probably need to use a semicolon between the two numbers.
Draw a rectangle and look what separator is used in the little box bottom-right on your screen.
it’s either a comma or a semicolon depending on your computers language settings.
Edit: Dave beat me to it…
Most likely your computers language or keyboard settings have changed…
