I am having an issue, getting the curved leader to work on dimensions. You’ll see I have it selected, but no leader is visible. I have tried playing around with all of the various options/settings. I’m also on the latest version too.
Is there something I’m doing wrong (see attached)? I have also attached a sample to show what I am trying to achieve (not my own file).
Thank you. Yes, curved leader was turned on. I have tried having it on from the start and also changing in in the setting once the dimensions have been set-up and neither seem to change the format. Happy to share the file.
Unfortunately that didn’t work for me either, but I have worked it out. For some reason it doesn’t default and I need to double click on the measurement, then drag it to the side to make the curve is visible. Very strange, but at least I have it working!
Did you try placing new dimensions after setting the extension line length to 1 mm? As I wrote before, it’s not going to fix the existing dimensions. Easiest thing would be to delete the short ones and replace them after correcting the extension line length.
As I show at the end, you can fix the existing short dimensions by first selecting the dimensions and enabling the leaders, it is likely going to be faster to delete the dimensions and place new ones with the parameters set correctly.
You might want to edit the dimension settings to remove the dot from the end of the leader since the short dimensions are so small on the page.
