Dimension tool problem
dimension problem.skp (15.1 KB)
Hey
My dimension tool is acting strange
Do any of you have a solution?
Not really enough info to go on. This certainly appears to be wrong but it might help us diagnose the problem if you attach the file.
Upload your model by using the 7th button from the left at the top of the reply box.
file added
I expect it’s a graphics card issue. When I ope your file the dimension looks the way I would expect it to.
What graphics card? Are the drivers up to date?
Have you adjusted the font size? I also get the same as Dave and my default shows as much smaller text.
I agree with @Box - I see the dimension text as 24pt, and it is possible that your system has an issue with that particular size of that particular font.
There is no difference if I change the font size… still the same issue but I will look into the driver and see if it needs a upgrade
Thanks
Help us help you.
Problem fixed
Going from 16 bit to 32 bit
Huh. I didn’t know there ever was a 16 bit version. I wouldn’t have thought to suggest upgrading to 32 bit for this. Glad you got it sorted.
In monitor settings
Capture
