Depending on how I rotate the view, the text of the dimensions will disappear:
Any ideas on how to fix this?
Do you have Hide When Foreshortened enable in Model Info>Dimensions>Expert Dimension Settings?
Share the SKP file so we can check it out.
No that option is not checked. Here is the skp:
Two Tables.skp (441.5 KB)
You are getting Clipping due to the distance from the origin and all the other text and geometry in between.
Oh. Well I have a lot of parts that need dimensions and I would like to keep them in the same file. Should I just try to distribute all of my scenes as close to the origin as possible or are there any other good ways to do that? Ideas are much appreciated.
