Has drawn a single rectangle in SketchUp, 3000X2000 mm.
I exported the file to DFX and opens it in TrueView. Then the dimensions will be about 3933 X 2622. What should I do for it to be right?
DXF?
Select standard view βtopβ and set the camera to parallel projection before the export. If the view is skewed when you export, you will end up with inaccurate dimensions.
