Hi All,
(SU & LO 2015 on W7pro)
I have design a house (metric) to exact sizes. Once imported into LO these dimension seem too rise by a factor of approx. 0.1% - This is to say, in SU a room @ 2310mm dimensions @2315mm in LO.
I have checked all the usuals - dim scale, etc. But no luck.
@DaveR; Yes, I can. In my frustration, I double checked the SU file for accuracy (all OK), then I changed the view scale from 1:100 (desired scale) to some other scale at random, then back to 1:100. This corrected the issue, but only on that view-port. Other had the same issue and were corrected in this way. I also changed the view-port from Hybrid to Vector and back again. This seemed to make no difference.
@Cotty; I used a combination of std views and redefined views (scenes) from SU. The model axes are square to screen.
@ALL; Thanks for the help, but I seem to have this licked; albeit as a work-around. I make absolutely sure the model is true to the dimensions I want so that when exporting to LO it should work without fudging the dims. I have also found that importing dwgs (accurate in AutoCAD) produce the same sort of error when they appear in SU.
There was a case a few months back in which someone had a similar problem and changing scales seemed to be the fix. I don’t know what causes it but it seems to be very rare.
One thing to make sure of is that your scenes don’t show as modified in LayOut’s SketchUp inspector window.
