I have a Sketchup Pro 2023 annual subscription license, I wanted to try diffusion, so I installed the extension Diffusion, the icon shows up, I can also see the Diffusion option in the extension menu, when I click on it nothing happens, the Diffusion windows does not show up.
I tried opening the Sketchup web version and the diffusion windows does show up as it should, so I wonder why it doesn’t work on the desktop version.
I’m also having the issue with the diffusion window not showing up even though I have a current pro subscription. -Icon is there, but greyed out like its not active. -No window pops up when clicked.
I tested that. Curiously, the ‘true’ didn’t change to ‘false’ until I tried the Ruby line a few times after turning off WiFi and disconnecting Ethernet.
Once Ruby and I agreed that I was definitely offline, the Diffusion button still gave me this window:
I opened up 3D warehouse which is fine (connected to internet) I also tried Ruby console but got back ‘Error#<NameError: uninitiated constant SketchUp’ - I’ve no idea what that means but still Diffusion window fails to show
It means you typed “SketchUp” instead of “Sketchup” (I do not know why the API writers decided not to use the same upper case U as in the product name for the Sketchup module identifier.)
