Difference between “Circular Cylinder” and “Polygonal Cylinder”
Many People still wondering why there is no shortcut for ‘Polygon’ in Sketchup. I would suggest those to please view this tutorial which briefly describes difference between “Cylinder” and “Polygon” shapes.
Watch the video here: http://www.youtube.com/watch?v=if3AUzpBuaE
I assigned it “Y” on my keyboard using Preferences that is found under the Windows Tab. Sketch Up`s keyboard shortcut defaults can be seen by using the Alt key to highlight the Tabs shortcut key. Use arrows to scroll across to the Tab you need and hit enter. All the default SU keys are darkened and the ones you assign from the Preference selection are grayed. Take the time to use theirs and figuring out how to assign your own. Not only a time saver but builds your confidence as in remembering and utilizing all that is offered with this Software.
This has got me stumped: while polygonal cylinders look and behave the way shown in the vid, circular cylinders have dotted lines along their facet faces. And yes, they have just as many faces as the polygonal cyls, not just one.
Is this a new feature of 2015, a setting I have changed inadvertently, or am I missing something else?
You have probably turned on Hidden Geometry (View menu).
SketchUp is a polygonal face modelling application, so there is no fundamental difference between a polygon and a circle. Both are segmented curves under the hood. When pulled into a 3D cylinder, the facets of a circle are by default smoothed. In Entity Info, a circle shows the correct area information, not the actual area of the polygonal face.
