I purchased two Sketchup cabinet design models from a cabinet designer, for me to build myself from plywood etc.
The Sketchup models came with some flat pieces of plywood, shown at right angles in the 3D model, and those pieces layout fine.
It also came with several diagonal placed pieces of plywood that he modeled as a rectangular frame with the wood spanning from one corner edge to the opposite corner edge. These are causing a problem for the auto layout feature of the Builder Free SketchUp extension (similar to CutList).
I want to select all of the parts of the cabinet model and hit the button âRun Builderâ to run the Builder Free extension, and get all of the parts laid out efficiently on sheets of 4x8 plywood, with minimal wasted wood.
When I hit âRun Builderâ (EDIT: was âsend to LayOutâ), Builder fails to find matching wood stock for the parts which were designed as spanning from the one corner edge to the opposite corner edge of the bounding boxes.
For example, one problem part is half-inch thick plywood, 24 inches wide, 16.5 inches long, displayed in the design as attaching by its four edges at an angle of about 25 degrees. The designer made it as a frame 24 inches wide, about 14 inches long, and spanned the wood from the top left corner to the bottom right corner. Because none of the rectangular frameâs dimensions (24 x 14 x 8) is half-inch thick, this plywood board fails to match my 0.5 inch thick plywood stock, and Builderâs auto layout fails.
How you would go about solving this problem of Builderâs auto layout failing for this piece, and for all the other angled pieces which were modeled as rectangular solids with wood spanning from opposite edges.
The maker of the cabinet design doesnât want to redo his work to model those 12 or so parts as flat pieces laying at an angle in space.
Is there some setting to make Builder Freeâs auto layout automatically interpret the model for these parts as, for example, just the half inch thick plywood, 24 inches wide, 16.5 inches long?
Hereâs an example file with only 2 of these âdiagonalâ boards in it for you to have a look atâŚ
Diagonal plywood boards fails to auto layout.skp (42.1 KB)
