Hi,
New user here, and need some time sensitive help. I’m a woodworker and prepared a few 3D cabinet models, and want to get a cutlist with cutting diagrams. All components are set to be plywood, 19 mm thick, but somehow, despite me being careful and whatnot, when I get the cutlist, I see two different thicknesses, one 19 mm, and the other very minimally thicker.
I literally copy-pasted every component from the same original to avoid such issues when generating individual components, but probably because I turned some of them around, or who knows for what other reason, some of the components got “thicker” along the way. Even if I undertake the enormous task of individually re-thicknessing components, I doubt I can avoid repeating the same problem, pushing, pulling, scaling, etc. manually.
Q1: Can I magically make all components have the same thickness? I doubt it but worth the ask.
Q2: Can I find a cut list plug-in that could ignore thickness and just put every component into the same cutting diagram based on length x width?
Q3: Any other suggestions, and/or how to avoid this really, really annoying problem in the future?
Thanks, your help is much appreciated.
Samil
