1 to 3 i can create with “onClick” but what i dont know is, how to programm the relationship of the Zposition of each module to a previous added module with different height.
If i replace Module 4, which is 180 units high with, lets say module 2 which is only 60 units high, the on-top stacked modul 1 should change its position in Z downwards, to sit properly on the adjacent module.
So i have to work with if functions in the Attribute components? How this can to be done?
And has someone a link to a good introduction into programming within SketchUp for real beginners (beside the documentation)
I’m imagining that the positioning principle is fairly simple as you position Comp1 in Z=0 then, position Comp2 at Z=0+Comp1!LenZ and so on for all 4 components.
The thing I haven’t done yet is replacing a component for another. I think it requires layers, having all components nested inside the same DC, and show the correct layer with some user action. User input table would probably be #1 choice but Onclick probably would allow you to cycle through options.
Someone more experienced might give you precise ways of doing it, I hope I unveiled some clues…
