Delete Dimensions
Can you delete all dimension lines with one command in Sketchup for Web?
You have to click on each dimension and delete them individually. It is not like guide points and guide lines.
Window-select as much as possible and delete is faster than individually…
When you window select, be careful not to select things accidently that you don’t want to delete.
If you have worked organized and have all the dimensions with the respective tag
That’s another benefit of using tags that I didn’t know.
Dimensions are non-geometric objects. The proviso to only put tags on groups and components does not apply to them.
