I’m wanting to grab every object in the model that has the same material as what I have selected, and then delete them. How do I do it?
If you use the search option of the forum you would have found this:
http://sketchucation.com/forums/viewtopic.php?p=276175#p276175
Thank you, I will plan to do more research before making a new topic from now on, Lord willing.
Are you referring to the SketchUcation forum?
No, this one. The link came out of one of the topics found by the search…
Experimental! Not really tested. Use your own risk! Backup…backup…backup…
However it should work… ![]()
Copy-paste this snippet to Ruby Console and hit Enter (Return)
You will have a right click (context) menu if you select only one group or instance which have a material applied on:
"Delete all objects with same material."
You can undo it!
module Dezmo
module DezmoDelSameMatObj_test
extend self
@@loaded = false unless defined?(@@loaded)
def get_same_mat_instances(ents, instances = [])
ents.each{|e|
case e
when Sketchup::ComponentInstance, Sketchup::Group
instances<<e if e.material == @mat
get_same_mat_instances(e.definition.entities, instances)
end
instances
end
def del_same_mat
model = Sketchup.active_model
sel = model.selection
@mat = sel.first.material
entities = model.entities
to_erase = get_same_mat_instances(entities)
count = to_erase.size
model.start_operation('Delete same material objects', true)
to_erase.to_a.each{ |e| e.erase! if e.valid?}
model.commit_operation
UI.messagebox("Object with #{@mat.name} material deleted: #{count}")
end
unless @@loaded
UI.add_context_menu_handler{|menu|
sel = Sketchup.active_model.selection
if sel.single_object? && sel.first.material
menu.add_item("Delete all objects with same material."){del_same_mat()}
end
@@loaded = true
end
end
end
Does exactly what it says. It will ignore objects that have their faces painted!
Awesome!
Now, what if I want it removed from my system and the context menu?
Just restart Sketchup.
