Dealing with Flipped Normals and therefore textures painted on the backface of model
Thank you.
Now someone give or sell me an extensions that adds even a minimal thickness to all my mistakes.
Look at Joint Push/Pull at Sketchucation. Maybe it’ll do what you want.
I model like people paint I don’t have a plan I create as I go.
I did add a limited amount of SKU materials and my own art on walls as
I find the material library quite limited
I was planning on adding it within UE.
Rebuilding it all from scratch in UE would take me 2 years due to learning.
I test built my floors and then use floors to make walls by rotating them
which turned out as a nightmare as one can’t seem to rename native floor components into walls
at a later stage.
Anyway I will battle on. Thanks for your heads up, although it rather leaves mine hanging.
I have tried to import into Blender ( am not an everyday user) it seems to display way more
BUT I can only see what its in front of me.
When I move back and orbit 80% of it disappears something with depth of field vision
I haven’t found to resolve …always learning and learning more
sometimes I think I live inside Youtube tutorials
It’s clipping, you can increase the clipping distance by hitting the N key, it will show the properties of the model, go to the view tab, there you can change the focal length and the clipping distance.
I think the highes value you can put is 10000, but it will make the edges look like if it’s without antialiasing.
Thank you for that. I will try to see that change.
