Can someone help me, as the datasmith plugin doesn’t recognise SketchUp 2025 as supported software
Have you contacted Customer Support at Unreal?
They do show that as of March 2025 it supports up to SketchUp 2024.
it support’s 2024 version of Sketchup but I’m talking about Sketchup 2025 version. I don’t want to go through the hassle of installing Sketchup 2024 and all of my plugins
I know that! I read your first post.
So contact Customer Support and see if they can tell you when they will support SketchUp 2025.
until they release an update that works ok with SU25, you’ll have to import in twinmotion / sync your files as you work.
they’ll eventually release one. eventually. at some point ^^’
Are you using the plugin to export to Twinmotion for rendering, or unreal? Twinmotion can import .skp files directly, simply save your file in SKP and in TM use the import function to bring in the model, you can update from there too. I find this workflow preferable to the datasmith plugin.
Thank you so much
