Hi John, thanks for your interest, I’ll see about uploading in a bit. The pic in my original post was intended t show the desired result. I need four of these in a neat row. Selecting, copying & pasting works easily enough. Problem is getting the pasted object to either ‘sit’ within the wall rather than in front o fit, or to show completely. Sometimes the interior detail is obscured by the wall surface.
Regarding the texture; I considered drawing at full size then reducing however, as I’m constructing pieces to fit within an existing kit bashed model it seemed better to model directly to the size required. If I can do it, what I’m after is a simple way to put in an embossed brickwork pattern, not simply a painted effect. If I can’t I’ll declare the structure ‘concrete rendered’ & paint it with all sorts of grime.
Let me get through breakfast & I’ll see about uploading the project.
