Cutting a section through a cylinder without solid tools
I’ve watched several Youtube videos over the weekend in regard to sectioning a hollow cylinder. All three I have seen refer to using solid tools (Pro version only). My question is, how can I achieve the same thing with skp 2017? I need to create an angled cut through one end of the tube I am creating.
Draw a face that slices through the cylinder at the desired angle. Use Intersect Faces to intersect the face with the faces of the cylinder. Then erase what you don’t need.
Or you could get BoolTools 2 and do the same sort of thing that can be done with the Solid Tools.
Thanks mate, that is exactly what I need to do. Much appreciated.
This might help too, works for me in 2017 version. Also works on angled joints.
