i have this detailed piece that I want to cut a bevel on. I can’t figure out how to do it easily…or at all without destroying it. what is the best way to do this? thank you
You could use multiple Push/Pull steps to do this but if I was doing it, I would model a “cutter” volume and use a Boolean Trim operation to cut the bevel. You could use Subtract from the native Solid Tools or, better, Subtract from either Eneroth Solid Tools or Bool Tools 2.
The manual version if you don’t have access to solid tools.
A tap on ctrl will allow pushpull to go all the way through.
I gotta pay attention to the that bottom left corner more often ! ![]()
great video! it took me a few tries but i got it. i cannot find a trash can icon in my tool set. not sure how it differs from the eraser? I’m on Pro 25.0.659
Thank you!
Thank you, this method is great for me. thanks for making me aware of solid tools!
It’s just a button that does the same as pressing the “delete” key
You’ll find it in the “standard” toolbar
or under the “edit” menu
One more way:
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
