Hey guys,
I’d love some help with a plugin I’m trying out: Curic Section Lite. I’ve created a section cut and chosen materials for 3 tags - walls, floor, and columns. The problem im running into is that the vast majority of the walls are not filling. I’ve checked the walls to make sure they’re all solids/no faces are missing etc.. can’t find any reading materials. Ill share a screenshot below, also I’ll share the model.
Any help is greatly appreciated, I really feel this plugin has so much potential but it seems like it might take a lot of time to set up simple section cuts.
Thanks
Mukuba Building.skp (1.4 MB)
Hi, when I open your file and check I see this.
This means the wall is not solid, so that the reason why you can’t see hatch created from Curic Section
After using Solid Inspector2 from ThomThom to automatically fix solid, your wall became solid and has volume.
Please note: an object in SketchUp is only a solid if there is “Solid” word (1) in front of it type and a volume info (2) appear in Entity Info although the Solid Inspector2 (3) report “No Errors, Everything is shiny”
I believe after fixing solid for the wall, hatch for that wall will be created.
Hey, thanks for the tips, great way to check if my objects are solids!
I went into my model again and used the solid inspector tool, then fixed all my groups to make sure they’re all solids. However, the Curic Section still isn’t reading the walls as solid. I added a normal section cut from SketchUp and the walls are just fine, but the section cut with Curic section tool still isn’t filling the walls.
