I’m having an issue using curic face knife where it’s deleting the entirety of the object, rather than the chosen shape. Has anyone had this before? And would know how to rectify?
Do you know what this object looks like? What are its dimensions? Where are you trying to cut it? What shape?
Hey Mihai. It was an L shaped deck. I ended up just inputting every board manually.
I have it all grouped, not in components, would that be a factor? I just got it to work on a different project. The only difference was that I have the others as a component
@Steven, I think I’ve found your problem. Probably, the component you are willing to cut, is composed of only faces. while using curic face knife I found that whenever I try to trim any face or group consisting isolated faces, the extension cuts the whole thing (sometimes leaving only the lines). Curic face knife doesn’t work well for isolated faces. You have to produce solid or group of connected faces
