Design Options for SketchUp
Hi, I’ve just released a new extension for SketchUp is Curic Design Option. Hope you like it.
Setup and toggle design options easy with tree UI.
Features:
- Tree UI: make group, clone node, context menu…
- Easy toggle design options in a group
- Support bind material, size, position, rotation of Objects
- Powerful descriptions: Text styles, insert link…
- Export 2D images
- Make Scenes
Sketchup version: 2017+
OS Compatibility: Windows, macOS
More info on the Facebook page - Check it out: Curic
Get the plugin here
Thanks.
for the materials, it would be super if it was also possible to save the texture position with each variant…
best, franz
Hey @curic4su @voquochai - Your design options plugin is quite amazing! I think the ability to save materials as @bsfranza has mentioned would really push sketchup forward for designers who are looking to easily present design options. It looks like you might have stopped the development on this plugin? Would you be able to add the materials options to it this year and continue pursuing it? It can be a really powerful plugin with that feature added and I think very useful to all designers using it.
Hey @curic4su @voquochai - I’ve been using this extension to fairly good effect however, is there a way to export templates out so I can reuse the same file tree on new files and retroactively fit objects into it?
Cheers!
I want to buy Curic Design Option, but first please confirm that after I buy you can also send me all the previous versions.!
Thank you.!
