Crush opening file .skp from layout 2025
Hi everyone! I have got some issue with opening .skp file from Layout 2025 when I am trying click “Open with SketchUP”. I have got the message:“Failed to open C:\Users\aakra\OneDrive???? ???\MURAVA\DOING\121.skp” and only one option - click “OK”.After that .skp file is crush. What I did wrong, can enybody explain me?
just upload ur file and wait colin help you
Looks like you are trying to open a file from OneDrive. Download the file to a folder on the internal drive and then try opening it. DO not work on files saved directly to the cloud.
The same way i do using Layout 2024 is working smoothly. :thinking:
Still not a good idea. If the access time is too long the file won’t open. Working directly on cloud-saved files has proven to be hugely problematic for many users. It has resulted in corrupted, unrecoverable files.
M.layout (524.2 KB)
This file opens just fine in LayOut 2025 for me.
Try to open using “Open with SketchUp”
I did. This is what I see.
I’m a bit puzzled as to why you’ve drawn three view of this table in 2D instead of creating a 3D model of it.
Maybe i have technical issue, because anything i did it is all the same problem with opening file. p.s Yes I have 3d model of this stand, but I’m using Make2D plugin by Curic when I make drawing in layout because rounded shape of stand makes some problem when you using dimension tool in layout. Besides I have the project of a lot of units furniture colected in one file. It woold be a problem when your layout file include 50+ unit of furniture with texture and geometry.
It shouldn’t do that.
Well, as long as you don’t have to make edits, I guess. Seems like a lot more work to me but it’s your work and you can work it the way you want.
