I am trying to draw up a fence.
I laid out the shape with rectangles (end posts and top rails) and lines (mid posts). Now I wish to turn those lines into tubes.
I have created a circle at the base of the post line and used the push/pull took to create a cylinder to the top of the post line. For the end posts, this seems to work well. However, when I use the same method to do the mid posts, I’m only getting a half cylinder.
Looks like you need to learn about using groups and components. If you had made a group or component of the fence before drawing the circle for the post, the edge of the fence wouldn’t split the circle.
