Would you please assist me to recreate the rail in the bottom pic. It is has got round edges/corners and bends where it is all welded to the fence but so far I was not able to come up with a technique to recreate anything similar. I have designed the support structre , however I want to replicate the top that has got the design and tried with follow me but so far without any satisfying results.
Could you please assist me ?
I would use Follow Me to create the rail and then cut the end off with a intersection operation. Hang tight and I’ll draw an example.
Here’s an example of DaveR’s method. Use the Intersect command to cut the half circle on the bottom.
-Gully
Usually not.
-G
If you solved the problem with scripting in SketchUp, would that be Ruby on Rails?
Thanks so much. This has really been helpful.
