Ok, so, i want to make a thin walled object such as a water bottle. How would you make it thin walled and empty on the inside, but yet a solid?
I thought of using a side profile and then follow me to create the revolution, but is there a simpler way?
also, is there a “shell” extension that will automatically shell out a part? take for example a block. you hit the shell button, assign wall thickness, depth etc, and it removes the other stuff. I know it could be done with solid tools, but it would require me to make a second block and position it. not a problem, but time consuming especially with odd shaped parts such as the one below. I know the offset feature would help accomplish this, but not for a water bottle haha
a rib tool would be cool too, but those can be drawn in pretty quickly
thanks
