I’ve been working on this project for several weeks now and for the most part it has gone smoothly.
There is one glaring exception to this. Creating the leading and trailing edges on a wing. Normally we’d simply make a airfoil section and extrude it, but in this case as you can that is impossible. I’ve tried everything, and thus far no success. I’d be grateful if someone could help me out with this.
Attached is what I’m trying to achieve (eventually).
So far, curviloft, follow (useless in this case anyway), the new Raylectron ‘connect tool’ and the sandbox contour tool. I don’t know what else to try?
Soften the edge indicated with the red arrow. Erase the edges marked with the blue arrows and the weld the border edges so they become curves you can select for Extrusion Tools.
So, work had me busier than a beaver in Spring. Thank you to @DaveR and @liamk887 for your tips. I have managed to make some progress, I think for the most part the geometry needs a lot of smoothing out to look the part.
