Hi,
I am fairly new to sketchup and have already created quite a complicated house layout. however I am now trying to make all my windows into “components”. I’ve followed a couple of tutorials and not had a problem. However I want to make a window component which I can place into a 600mm deep wall. All the examples I have found just place the create component into a single skin flat wall. If I just create a simple rectangle,erase the centre and then select all lines and make component, checking the cut holes option it doesn’t cut through the inner face of the wall only the outer face. (no real suprise) If I create the window using Push/Pull to get a 3d opening, then select all the lines of the op ening inside and out, create a component and then try to place it … it does not sit inside the wall and thus creating a hole… its sits on the outer face… then refuses to allow me to sink it into the wall with the move tool… I’ve attached a screen shot of the second try above…
any help appreciated…
Cheers
driving me slightly mad… I know it’s simple but can’t seem to get the right solution.
