Create separate drawings from plan & elevations
Can I create five separate drawings from one drawing sheet containing
a plan & four elevations ?
Is your model 3D? If so you can create a scene for each elevation and the plan.
Thanks Dave, I’m not familiar with creating scenes but I’ll look in “help” for the solution.
Essentially a scene is a fixed camera position for the view you want. If you want 2D plane and elevation views, set the camera to Parallel Projection and then choose the view you want from the Standard Views toolbar or in the Camera menu. Zoom as needed to show the area you want and then, in the Scenes window, click on the + in the circle to create a new scene.
