SU is intermittently crashing when I try to open the component rolldown. It does it maybe 1 in 3 times, frequently enough that Ive had to set autosave to every minute. Doesn’t happen with the other rolldowns and didnt occur in 2025.
I looked at the two bugsplats you sent in. It looks like there is a “face me” component that leads to the crash. Are you getting this with even the Simple template, or only your own model?
Can you say what “Component roll down” is?
If you only see the problem with your own model, can I try it?
The roll down is what I call the tabs that contain entity info, tags, components, outliner etc.
I haven’t tried with the simple template. It’s done it with a couple of models using my own template which I can try to send you. What’s the best way to do that?
